Hey guys! Long time m3forum member here. This is my first thread. After installing my new interior, I could not get one of the bolts to go back in. It is the rear right bolt on the driver seat. I’ve even tried a different bolt, and it just won’t go in! I don’t want to use too much force and strip it. Has anyone dealt with this before? Thanks
Seat bolt won’t go in?
Originally posted by Bostonbruck View Post
Thanks for the reponse. I forsure did that, all the other bolts were loose. It screws in a couple times then stops
Loosen the others and jiggle the seat around until it lines up. Or, undo the others, do that one first, then do the easy to see ones.
But, whatever you do, don't force the issue!
Originally posted by SQ13 View PostTry lifting up the back of the seat a little while installing the bolt.
have you tried to put the bolt in with no rails? You SHOULD be able to start fastening the bolt in with your fingers with little to o resistance. If it’s really difficult just doing this you should check to see if any threads are damaged or there may be debris inside the hole.
if there is debris in the hole, try compressed air first. If not then you may need to use a thread chaser. It’s easy enough to make one.
Originally posted by Bostonbruck View PostI can start it with my fingers but once it’s a couple turns in, it just gets stuck. It even does this when no seat is in the car. I definitely don’t wanna force it. I think I’ll just have to have a shop fix it when I take it in the for subframe.
Did you possibly start to cross thread it at some point? How do the threads look on the bolt?
