The carbon slicktop thread
  • Slideways
    Any recs for a shop in Texas that has done CF roof installs on the E46? The car lives in Houston, but for a job like this I don’t mind traveling for quality work.
    Either that or I just suck it up and DIY the install, and hope that I don’t screw it up.
    For a major job like this, only go with a shop you can prove has done many installs. If possible, find an example to inspect in person. The last thing you want is for them to experiment on your car and skip something in the installation instructions. There is a video of a Karb CSL roof that had to be removed due to a defect and the fact that the shop installed it slightly crooked to the point where the roof rail fitment was off.
    George Hill might know a place in TX
  • SQ13
  • AWE46M3
    How much was the installation in total? I found their rate-to-quality ratio to be very reasonable on some paint work they did for me.
    $1500 for the roof + a couple hundred to install new ABC trim panels and the slicktop headliner. They charge 1500 to do the roof only and usually put the CF roofs in race cars so the interior work is a little extra.
    Originally posted by gohdunlam View Post
    wow that looks clean
    Thank you 🤝
  • gohdunlam
    Finally got my Karb roof installed thanks to Kings Auto Body in Huntington Beach. The weave on the roof is exceptional. No QC issues to note for the clear coat or finish. The roof is getting Suntek PPF done this week. I had a chance to look at Xpel and Suntek on CF roofs and prefer Suntek due to the smoothness of the film whereas Xpel is more heavy-duty and comes with a noticeable orange peel.
    Huge shout out to Tbonem3 for the glam shots. The iPhone 14 Pro would not have done this justice.
    Click image for larger version Name:	nick+sge46 (6).jpg Views:	0 Size:	78.9 KB ID:	219931
    Click image for larger version Name:	nick+sge46 (7).jpg Views:	0 Size:	22.3 KB ID:	219932
    Click image for larger version Name:	nick+sge46 (8).jpg Views:	0 Size:	29.9 KB ID:	219933
  • Nate047
  • AWE46M3
  • Epsilon
    Maybe this was covered but can you bond the cross beam, or does it need to be welded in?
    This guy bonded and added rivets.
  • repoman89
    Originally posted by ImAzn View Post
    For those that went with the Euro Headliner without the hump, what did you do with your motion sensor in the middle? Or should I just get the one with the hump?
  • Wernd
    I believe euro is perforated so you could cut it out. I don't know if the plastic would fit or not since it snaps in and does sit up a bit from the headliner. I guess worst case you could trim the plastic shorter too
  • old///MFanatic
    Doesn’t the “euro headliner” have the option of cutting the marked hole or leaving intact. The motion sensor doesn’t really take space behind the hole, other than the white plastic bracket backing and to hide wiring.
  • ImAzn
  • Duck360198
    Soooooo does anyone have an OEM CSL roof laying around they'd like to sell? Or know where to get one?! Just curious!
  • Nate047
  • 0-60motorsports
    Originally posted by Mtrace View Post
    In the thick of it at the moment
    Nice!
  • Mtrace
