The carbon slicktop thread
  • bigjae46
    Wear a respirator if you cut/grind or even drill carbon. The dust is as bad as asbestos.
  • SQ13
    Forgive the denseness but I'm still a bit confused. You're basically saying because of the lack of angle cut on the front of the karb roof, the panel does not sit as flush as it would if there was an angle cut like on the OEM panel, and thus might have adherence/gluing issues? Also the roof is an extra 7mm forwards because of it?
    Yes, installing as is would cause the roof to sit on top of the nub, which would cause a large gap between the roof and flat portion of the body. This would most likely cause issues with windshield install.
    You must do one of the following to prevent this:
    1. Grind down the nubs
    2. Cut roof corners at an angle like OE to clear the nubs
    No, the overhang is not due to the above..it’s a separate thing I noticed. The front lip just happens to be larger on the Karb roof. You can either leave it or cut the excess lip off. Only one person has documented cutting off the excess; after watching some vids and talking to some people who have installed the Karb roof, I’m pretty sure most people just leave it.
    The fitment of the roof is perfectly fine. The alignment of the exposed/raised portion of the roof lines up perfectly with the roof rails and pillars.
  • CrisSilberGrau
    FYI for those who are installing a Karb roof… The corners on Karb roof are not cut at an angle like the OE and other aftermarket roofs. The angled cut allows the roof to clear a welded nub on each corner, and I believe it avoids contact with a layer of sheet metal for the A and C pillars (will confirm this tomorrow since apparently none of the pics I took contain fully exposed corners). If the second point is true, that means the roof will sit more flush with the body/bows. Additionally, there is 6-7 mm of overhang on the front edge of the roof.
    It’s kinda surprising that after looking thru this thread, other online posts, and in the vids I’ve seen for the Karb roof install, only one person mentioned the overhang and no one talked about the nubs. I think they ended up grinding down the nubs and leaving the overhang as is (except for the one forum member here), which I’m sure is fine. I’ve been tempted to do this as well to avoid the extra work of cutting carbon fiber lol.
    Anyways, the point of this post is to let future Karb roof installers know that Karb recommends cutting both the angles on the corners and the overhang. And to clamp the front and rear edges every 10-15 cm, especially if the roof is slightly raised at one corner. BMW’s official install instructions calls for five clamps each on front and rear edge….as long as you’re not using two clamps like I’ve seen some people do, you’ll probably be fine. Just follow either Karb’s or BMW’s instructions. And wear proper PPE if you end up cutting the roof—you do not want to inhale the CF dust and have fibrosed lungs.
  • CrisSilberGrau
    Part of me wants to try having the roof painted in a sort of "fade" silver grey. From a distance it would seem to be paint matched to the car, but up-close, the weave shows through.
Name:	cf roof 11.jpg
    How dare you...
  • Cronenberged
    Not sure I understand?
    If any of the details from the OEM panel are imprinted in the CF panel. It looks like it, but the limited quality on the forum doesn’t show it. Mostly looking at the edges that will be in contact with the frame when adhering it.
  • bigjae46
    bigjae46 can you show depiction of how similar your CF roof is to the OEM panel.
  • Cronenberged
  • Sid_E46
    For those that used 3M Panel Bond...how many 200ml cartridges did you need?
    1 was more than enough.
  • bigjae46
  • Nate047
    Nooooooo leave it
  • Sid_E46
  • 0-60motorsports
    1x1 spread tow roof completed! 5.6lbs. Straight out of the mold, no clear coat. Weighed a slick top roof panel - 18.4 lbs.
    It feels a little stiffer than the OE roof when trying to twist the roof diagonally.
    Click image for larger version Name:	IMG_3997.jpg Views:	0 Size:	228.5 KB ID:	288302
    Click image for larger version Name:	IMG_4003.jpg Views:	0 Size:	273.7 KB ID:	288305 Click image for larger version Name:	IMG_4005.jpg Views:	0 Size:	173.8 KB ID:	288306 Click image for larger version Name:	IMG_4002.jpg Views:	0 Size:	144.4 KB ID:	288304
    That weave looks so sexy! Nice work brother.
  • bigjae46
  • SQ13
    Lol I did all of the above and still struggled with it. Def not a quick job for me 🙃 i followed the instructions but my technique was probably poor. Glad it’s over now
  • heinzboehmer
    1) the bit walking off
    Did you center punch the spot welds? I bet that helps a lot with the walking.
