Who currently codes the DME’s to CSL?
    So, I have a ZCP dme that’s tuned for aloha N, but I’m looking to go to a MAP/CSL tube. I’ve heard good and bad about Kassel, mostly that the wait times are months out, which I do not want to wait for.
    Is there any state trustworthy* shop or individual that offers this service?
    If you don’t want the flap you can do it yourself with mssflasher and Terra’s modified CSL file without even removing the DME. Couple pins on the wiring harness at the DME need to be switched around and added for the MAP sensor and IAT of course as usual.
      Chasen I am disappoint
      Where's Corey?
        Where's Corey?
        Texted him lol
        He swore to me you need to ship it out..
          I used kassel.got the DME in a week.
            Where's Corey?
            “I wouldn’t recommend that method. It’s a hack and sketch. Could brick the dme entirely. Kassel told me a month ago the lead time was only a few days so I’d call or message him on Instagram and see if that’s still true.”
            From C dawg himself
              Corey must be thinking about the H bridge for flap?
                This.
                Unless you want the flap, just flash it.
                  From C dawg himself
                  It's not likely to brick the DME. Even then, there's a way to unbrick it which at that point you've not really spent more money. I recently had to do a cluster, which is the gateway of the car. With Terra's modified CSL tune, I flashed my old file onto it, coded my instrument cluster, and coded the DME back to Terra's CSL. If something goes wrong with a module, you have less hassle.
                    A guy on the UK Cutters M3 forum does it remotely if you don't need your DME converted to HP spec.
                    Regards
                      I'm looking for someone as well. I had my ECU converted to CSL software by Kassel. Everything worked fine, but I needed to flash back to an earlier hardware version for my State's Emissions. I had someone remote in put the U.S. spec tune on my car with an Alpha N tune but they couldn't do it. Fine, I'll send it back to Kassel and get them to bench flash it back to the original U.S. Spec then have the tuner remote in and put an Alpha N tune on it. I got a message from Kassel that they can connect to the ECU via OBD, but can connect to the chips so they can't flash it back. They said they had never seen this so I am looking for someone to try with their setup. It doesn't make sense. The car works fine.
                        Check out Kassel Performance
                        E46 M3 LSB
                        F80 M3 Sakhir
                        F86 X5M Alpine
                          Chas3n, let us know who you end up using and what your experience is.
                          Kassel has too much negative feedback IMO.
                            I’m going to have Hassan flash to CSL at the moment. There’s no good options to send out, unfortunately.
                            That said, I don’t have smog/inspection requirements, so if you did it definitely doesn’t sound like a good option.
                              In theory, could you buy an ECU off Ebay and have that ECU coded to your car? Would that cause any problems? Also, to extend that thought further, could you buy a non-HP ECU for a car that was originally fitted with a MSS54HP and work with that ECU if you had no intention of ever using the flap? I am at a f**k it point with a current issue I’m dealing with where it is fix the ECU or buy a trailer.
                              Edit: Could the “new” ECU be coded to the car remotely or would it require a bench flash?
