Need Belly Pan Recommendation
    I've been able to search and find quite few belly pans, but mine needs to be replaced after a good quarter of it got ripped off. If anyone has any experience or recommendations with the ones listed below it would be greatly appreciated.
    BW - CF $999
    Turner - $500 strongest looking
    OE - $190
    Motion motorsport - $178
    I have the motion motorsports panel. It’s a nice piece but it did take them a long time to get it to me.
      I have the Turner and I wish I would have just kept it stock. The Turner is a beast but it's heavy. It's a pain to install as you have to replace not only the brackets but drill out and install riv nuts. On my car I had to remove the windshield washer tank in order to install the riv nut.
      The stock plastic will at least flex if you bottom out, where the the Turner will not.
      2005 ZCP SMG ///M3
        The stock plastic one actually creates downforce based on the shape. It’s ’wing shaped’ being lower at the front which would create a lower pressure area behind it and smooth out air as well. I would stick with the OE.
          Stock. Least money, least hassle, best engineered.
            Stock from fcp. That way, if you damage it again, free replacement.
