You've got like 80k miles till you need to do bearings fyi
Eight of the twelve that I pulled out at 98k were completely worn through to the copper layer. It’s definitely worth doing if you don’t know the history of your car.
I understand what you're saying and I do agree with it. However my track buddy is also a mechanic so the only cost incurred is parts. Since I don't know the history of the oil changes I'm just going to do it
So how bad has your maintenance been between this miles? I am at 125k with all the big stuff out of the way but curious what else I might be in for.
Outside of the big 3 which were by far the most expensive (I neglected VANOS and it bit me in the ass), I've encountered just about all of the most common issues during my last 7 years of ownership.
Looking through my records: water pump, fuel pump, TPS sensors, leaking coolant expansion tank, starter motor, CPV o-ring, valve cover gasket, ignition coils – but these are all expected at some point given the age of these cars, and none of them were particularly expensive since I did the work myself. Have also done some rubber parts like shifter refresh, motor mounts, trans mounts, steering guibo, then of course fluids, filters, spark plugs, belts, etc. which are all routine.
The big one on the horizon is going to be a full suspension refresh, which is definitely overdue at this mileage. Just got done with the clutch / flywheel, which miraculously appear to have been the original units at 180k.
Certainly not a trivial amount of maintenance, but at this high of mileage I figure most cars would start to have issues like these pop up.
