Originally posted by Under_Pressure
F80 Brake upgrade on E46 M3
Originally posted by jager911 View Post
If money was not an object, sure! You posted links for fronts only for $3k and $5k. I'm working on ~$8k upgrade currently with VANOS, cams, headers, CSL airbox and dyno tune. The reason I was interested in F80 is mainly as a budget BBK, it's definitely better brakes than in 2003. I'm getting F/R calipers with new front OEM rotors for cheap but I will pass since I don't want to buy new wheels now. When I win the lottery, I'll look at Essex and AP Racing. In the meantime, I'll go back to budget build using 996 or Boxster S calipers to keep costs reasonable.
That's why I suggested the Essex kit- proper 2 piece rotor assembly with floating pins, better metallurgy in the rotor, properly directionally vaned, with a much better caliper.
Im using F80 Front Brakes with the Porsche rears and they work great on track. I agree that if money was no object then id be rolling around with some APs for sure. Had the full Porsche setup but I really like how my current combo works. Im not on APEXs though and old ARC8s will not clear, using a set of BC Forged wheels currently but new wheels will be showing up sometime in April.
Originally posted by PHNX636 View PostIm using F80 Front Brakes with the Porsche rears and they work great on track. I agree that if money was no object then id be rolling around with some APs for sure. Had the full Porsche setup but I really like how my current combo works. Im not on APEXs though and old ARC8s will not clear, using a set of BC Forged wheels currently but new wheels will be showing up sometime in April.
How was the 996 F/R set up on track? Was it a worthwhile upgrade over stock brakes in terms of feel and brake pad wear? That's my current default plan due to budget.
And in case anyone is wondering the f80 setup is a pound lighter all in all.
M2 (same as M3 and M4 I believe):
-Front caliper: 10.78lbs
-Front rotor 380x30: 24.89lbs
-Rear caliper: 7.94
-Rear rotor 370x28: 20.39lbs
Total per side: 64 lbs
996/M3 CSL brake kit:
-996 front caliper: 6.4lbs
-M3 CSL 345mm front rotor: 19.1lbs
-996 rear caliper: 5.2lbs
-M3 CSL 328mm rear rotor: 15.9 lbs
Total per side: 47 lbs
Youtube DIYs and more
Help me understand what you are including in that. F8x vs 996 approx numbers I have:
-Rear caliper: 7.94
My f80 setup is with racing brake rotors which were 20ish lbs
996 setup was weighted with creation Motorsport brackets, which I don’t recommend at all.
The rear stayed 996 but you’re right stock for stock the 996 would be lighter. I apologize.
-Rear caliper: 7.94
With more heat capacity, lesser diameter and inertia with weight closer to the center.
Is anyone running those?
It looks appealing to me with those attributes.
Not sure if the kit is any good for street also. Since they don’t run dust boots, but they say they don’t need to.
They say it’s designed to run these wit OEM M3 rear brakes for track.
I remember them on last Black Friday for something 2700$.
Originally posted by RazorM View Post
What About Essex AP Racing 325mm kit? They are additional 10lbs weight savings on the front axle to 996/csl and 27lbs lighter to F8x kit.
https://www.essexparts.com/essex-des...t-cp8350-e46m3
I would get Brembo GTS 355x32 or AP Racing Radi- Cal BBK instead.Last edited by Gt4; 02-01-2024, 03:22 AM.2002 BMW E46 M3 Titanium Silver/Black 6mt
2006 BMW E46 M3 Individual Estoril blue/Black 6mt
2019 BMW X3 M40i Phytonic blue/Tartufo Individual
CP8350 is a good entry level caliper but not for the heavy E46 M3 platform. Flex too much IMO. I had them on a previous track car with same pads (PF01) as my PF45 BBK and there was a huge difference in pedal feel. 345mmx32mm front rotors also help.
I thought that it may be bit of a trend, since stoptech also started to sell C43 BBK set, which is using the same philosophy, ultralight 4pot caliper without dust boots and smaller than usual 324x32 disc. They say the caliper is 50% lighter than ST40Last edited by RazorM; 02-01-2024, 03:45 AM.
Originally posted by Slicktop View Post
Cool! Will be interested regardless as I am doing a similar setup this spring too.
I forgot to update this thread with my- dyno results. I got the engine mods completed along with Beisan VANOS kit last year. With 288/280 Cat Cams, CSL airbox, Euro headers, El Diablo muffler and on Alpha-N HTE dyno tuned, it made 346WHP which I estimate met my goal of 400HP with 15% losses. Hassan said it needs better exhaust to make a bit more power, I changed to a race muffler and will get it dyno'd again. On the original topic of BBK, I ended up going with the tried and true Porsche 996 f/r gathering parts. I just dropped off calipers at machine shop and looking forward to better brake feel and pad wear. Related topic, what happens to ABS with adding non-original calipers? I currently experience ABS ice mode when braking from 130 on the track and need to modulate the brakes. The first time, it was terrifying until I read about ice mode.
Originally posted by enjoy_m3 View Post
very nice, Are you running upgraded valve springs?
