Motion Control suspension
    I did a search for motion control and didn't get any results. I'm curious what experiences people have had with their 2 way or 3 way systems and if they had any advice about them. I'm ready to pull the trigger on a set of 3 way remotes and I'm just looking for any info the forum members might have.
    Thanks
    Try searching "MCS" Few write out "motion control."
    Asking people about suspension is futile imo. You're going to get all sorts of answers/opinions.
      They look pretty nice just by looking at them. Never tried them.
      The only thing that concerns me is how much hose there is from the body to the reservoir. It's not really ideal. They're also pretty expensive, so it depends what you're after.
        I have a MCS 2WR on my track-only M3. It would be considerable overkill on a street car (my street M3 is GC).
        Per MCS - a MCS 3-way is for professional race cars that have a team suspension engineer to make constant thoughtful changes based on changing track conditions.
          It is for a track car. What spring rates did you go with and did you wish you had gone with a different rate? Bimmerworld recommended 750 f 900 rear
          Tbonem3 thanks I'll try that. Actually it says MCS is too short a term to search
              Thanks! It hasn't helped me decide 2way or 3 way but it did tell me the spring rates I ordered from Bimmerworld are going to be ok on the street to and from the track
                Lots of videos and info on 2 ways. Seems the 3 way are for race teams. I would go with 2 way unless you're a suspension rocket surgeon and know it all already.
                  More adjustment could mean better. Could also mean more room to screw it up. I've seen more people fiddle around with suspension knobs and never get it right.
                  Unless there is a reason, I would recommend 2 ways. I'd also consider any potential race or time trial rules you might run into in the future. I believe BMWCCA has some restrictions on remote reservoir suspensions in some classes.
                    I have 1WNRs with flat ride spring rates 450f/850r with a 30mm front bar and stock rear bar. I love them. Truly a high quality damper and even with reasonably high spring rates it feels very streetable. 1WNRs are great if you just want to set them and leave them. 2 ways give you more adjustability but I would steer clear of the 3 ways unless you really know what you’re doing.
                      More adjustment could mean better. Could also mean more room to screw it up. I've seen more people fiddle around with suspension knobs and never get it right. Unless there is a reason, I would recommend 2 ways. I'd also consider any potential race or time trial rules you might run into in the future. I believe BMWCCA has some restrictions on remote reservoir suspensions in some classes.
                      Ditto these comments. I went from older JRZ 2-way to MCS remote canister 2-way on my T1 race/track car. The MCS were more finely adjustable and a noticeable improvement over the JRZ. Three-ways seemed a bit overkill for me as an amateur.
                      Don't forget to upgrade the springs as well. My front springs were way to soft for racing.
                      Feff
                      MVP Track Time
                        Using the most “street” friendly adjustments on the 2WR, how does comfort feel compared to stock suspension?
                          A reminder: Motion Control states that 2W-R should be factory rebuilt every 3 years. It is not inexpensive.
                            are you sure about that? normally it would be based on mileage and the rough guideline on their website is
                            25k street
                            20-25k street +HPDE
                            150 hours sprint racing etc
                              25k street
                              20-25k street +HPDE
                              MCS does tell you that time is also a factor for rebuild, though for my use it doesn't matter much
