Originally posted by oceansize
View Post
Look inside of a diff that had the M Clunk
The 4 spiders (small ones) and the 2 side gears (large ones) don't rotate on a straight road, so they are harmless. They rotate only during a turn. I wouldn't replace these gears for no reason.Originally posted by Cubieman View PostLikely what's going on with mine, I have the diff. out and the passenger side OPF not only has what I feel is too much (I know there should be some) rotational play but also some up/down play.
Where do you source the spider gears once worn down? I would love to take this opportunity to rebuild the diff. but unsure of my ability to put it together correctly.
Just shim up the side gears for less plays between side gears and spiders.
There’s really no reason to just put the shim in. You have to take the LSD carrier apart to get the large spider gear out to install the shim. You’d at least want to replace the clutches and steel plates.Originally posted by 0-60motorsports View Post
The dont sell it separately any more as i wanted to buy it and they said i would have to buy it in a package with other parts.
Yeah I got it but also labor is cheaper here so I wouldn’t want to do the new clutches and steel plates on my low mileage diff that only has some play but not much and just install the shim.Originally posted by bigjae46 View Post
I guess I’ll just wait and do a full rebuild in a year or so.
Here is by far the simplest/best explanation of how a diff works: https://youtu.be/yYAw79386WI
Youtube DIYs and more
I think what you want is these, but honestly, folks reuse them. These bolts go through the cap and the case, and main thing for these is to use a thread sealer so that diff fluid doesnt leak out.Originally posted by Cubieman View PostDoes anybody know the part # axle cap bolts? I don't know that I should re-use these..
To get the spider gear shim in, you have to take out the clutch pack anyway. Clutches don't last more than about 25k miles until they develop play, so even "low mileage" could benefit from it. Work wise, to get the clutch pack back in, you might as well use a new set...Originally posted by 0-60motorsports View Post
I understand your logic, and that is why i will wait for a sale on the parts, buy them and keep them on stand by for summer or after and do the job thenOriginally posted by mrgizmo04 View PostTo get the spider gear shim in, you have to take out the clutch pack anyway. Clutches don't last more than about 25k miles until they develop play, so even "low mileage" could benefit from it. Work wise, to get the clutch pack back in, you might as well use a new set...
Mind you that all this information regarding the diff in the torque spec PDF is pretty much wrong.Originally posted by Cubieman View PostDoes anybody know the part # axle cap bolts? I don't know that I should re-use these..
The specs quoted here make very little sense, but I believe they are based on the specs for a K type differential (K stands for german Kurz, which means short, which refers to the output flange style).
Those specs are 10 Nm + 40deg.
However, our M3's don't have a K type differential, but rather the old style output flange. Which should just be torqued to 22 Nm!
Furthermore the PDF calls for Loctite 242/243 which are medium strength threadlockers, while TIS calls for Loctite 270 which is a high strength threadlocker.
Since these bolts should just be torqued to 22 Nm, they are not torque to yield and don't need to be replaced.
Hope this helps.
This does help, thank you.Originally posted by bmwfnatic View Post
Hope this helps.
I do want to apply some RTV to the bolt threads as well as threadlocker but not sure if that would work with both compounds on the same bolt.
I would think one could put the threadlocker down at the end (tip) of the bolt threads and then the RTV sealant above it as to hopefully not let the RTV cover over the threadlocker as the bolt is installed.
Any thoughts?2004 Silbergrau Metallic 6MT
If you would want to apply both, then yes your way of doing it makes the most sense versus doing it vice versa.Originally posted by Cubieman View Post
Any thoughts?
However keep in mind that RTV isn't the same as thread sealant, and they serve different purposes.
When I rebuilt my diff I used Permatex High Temp Thread Sealant https://www.amazon.com/dp/B000AAJTYS
On the data sheet it states that it resists vibration loosening and works up to 400F, so it seemed ideal for this application, and eliminated the need to use an additional threadlocker for me, my bolts have not come undone and aren't leaking either 😁
- Likes 2
They do, they go all the way trough.Originally posted by bigjae46 View PostHoles don’t go through the case so RTV would serve no purpose. You should blow out the holes to make sure there is nothing in there.
Sent from my iPhone using TapatalkE46 ///M3 • 12/2002 • phönix-gelb • 6MT
Do not. There is a bump on the backside. It’s a blind hole.
