Just this one part - $900 plus the cost of the part. Need stands, clamps, a vacuum pump, resin trap…it’s a ton of small stuff. Plus safety gear. A good respirator, gloves, coveralls or tyvek suit.
I’ve worked with fiberglass before. Probably want to start hand laminating FG stuff first. It’s a lot cheaper to learn what working time means with polyester resin and FG.
Yeah the guy mentioned practicing with fiberglass first because it is not likely a first timer will get it right. This is an art in and of itself.
There was literally a small series of a guy going through everything to buy but I have no idea when I watched and how I found the series. It was back in 2018 or something. He had a 7 or 9 part series on supplies, building the mold, and doing the job. One day I hope to run across it so it can also be posted. I spent about an hour looking today. What was the overall cost of doing this job including getting all the starter supplies and tools?
Those videos from Easy Composites are where I started. Over the past 6 months, there is a lot more info on the internet. The hard part has been knowing what to buy. Simple stuff like the gum tape...there's a specific gum tape you need to get.
By far the worst part is cutting/sanding. You need a respirator and something to collect the dust. I only cut/sand this stuff outside of my garage.
How did you get education on making carbon fiber parts? All online?
If there are kits/homemade materials that are relatively inexpensive I would love to try my hand at some small stuff.
Great work!
I'm have not dabbled in this yet so not an expert by any means however this three part series actually was really helpful in explaining how to.
