Originally posted by bigjae46
When to prime the oil circuit
IIRC fuel pump fuse is # 54 or thereabouts.
If you did some "serious" engine work you'll want to crank for a lot more than 3 x 10 seconds... I crank it until the oil pressure light goes away.IG: @limited.slip
Alpine White E90 M3 6MT
Alpine White 1 Series M
T̶i̶t̶a̶n̶i̶u̶m̶ S̶i̶l̶v̶e̶r̶ E̶3̶9̶ 5̶4̶0̶i̶ M̶-̶S̶p̶o̶r̶t̶ T̶o̶u̶r̶i̶n̶g̶ S̶6̶2̶ 6̶M̶T̶
Originally posted by bavarian3 View PostIs there clarity about the proper way to disable the fuel system?
Do I need to go into the glove box to pull the relay or is there an easier way.
Note that a properly working fuel system will retain pressure for awhile and if you just pull the fuel pump fuse without bleeding off the pressure it will likely momentarily fire up. So you can pull the fuse with it running and let it stall out, crack a fuel line open or disconnect the coils.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
F54 is the fuel pump fuse as Kaiv stated.
Note that a properly working fuel system will retain pressure for awhile and if you just pull the fuel pump fuse without bleeding off the pressure it will likely momentarily fire up. So you can pull the fuse with it running and let it stall out, crack a fuel line open or disconnect the coils.Last edited by Slideways; 09-23-2024, 12:30 AM.
