I will be editing and adding to this over time rather than all in one lump sum. This will take hours to search for so bear with me. If I miss one, let me know. Cntrl + F is your friend.
This is a brief mention of info on e46 M3 maintenance/lockdown thread - NA M3 Forums however, this is to give actually details, part numbers, and accurate intervals. My source is not a mechanic or a shop, it is BMW.
Engine Oil
Transmission Fluid
SMG
Power Steering(when ATF is used)
Known specs:
Weight: Dex VI
Shelf life:
Maintenance Interval:
Approved brands: Texaco
Part number: 81 22 9 400 272
Note: CHF and ATF oils must not be mixed. The oil types are indeed compatible, but if there is more of the one type in the steering gear than the other, this adversely affects the properties of the other oil. it is permissible to mix Pentosin CHF 4548 with CHF 7.1
A/C
Coolant
Differential
Wheels to Hub
Pedal Bushings
Brake Fluid
Fuel
Engine Oil
Additives:
Known specs:
Weight:10W60
Shelf life:
Approved brands: Shell manufactures OEM, LL 01 spec required, Castrol TWS Supercar still has the ok from BMW
Part number:
Known specs:
Weight:10W60
Shelf life:
Part number:
Transmission Fluid
Additives: "BMW manual gearboxes are designed in such a way that there is absolutely no need to use oil additives."
Known specs:
Weight: 75W80
Shelf life:
Maintenance Interval: BMW states "lifetime" however this doesn't exist.
Approved brands: BMW MTF-LT-2
Part number: 83 22 2 339 219
Known specs:
Weight: 75W80
Shelf life:
SMG
Additives: None
Known specs:
Weight:
Shelf life: 5 years
Maintenance Interval: None officially, however it's a good idea to not exceed 5 years due to shelf life
Approved brands: Pentosin CHF11S
Part number: 81 22 9 407 758
Known specs:
Weight:
Shelf life: 5 years
Known specs:
Weight: Dex VI
Shelf life:
A/C
Additives:
Known specs:
Weight:
Shelf life:
Approved brands:
Part number:
Known specs:
Weight:
Shelf life:
Approved brands:
Part number:
Coolant
Additives:
Known specs:
Weight:
Shelf life:
Approved brands:
Part number:
Known specs:
Weight:
Shelf life:
Approved brands:
Part number:
Differential
Additives:
Known specs:
Weight:
Shelf life:
Known specs:
Weight:
Shelf life:
Wheels to Hub
Approved brands:
Part number:
Part number:
Pedal Bushings
Approved brands:
Part number:
Part number:
Brake Fluid
Known specs: DOT 4 minimum.
New BMW brake fluid is DOT 4 ESL which is a lower viscosity however they claim performance is the same. This is for the newer DSC systems where the reservoir is directly attached to the valve block.
Shelf life: 2 years
Maintenance Interval: 2 years for stock fluid. 1 year at most for DOT 5 fluids.
Shelf life: 2 years
Fuel
Additives:
Shelf life:
Shelf life:
