Originally posted by AussieE46M3
View Post
I'm dealing with a noise problem on my daily driver. A bit of background: I've put new diff bushings on two different E46M3s, both with the subframe still installed and the car on jack stands/quickjack. On the first car (at 150k miles) with a freshly rebuilt differential I used a BMW OEM front bushing and Powerflex rear bushings. I used Powerflex rear bushings to save about $100USD. The car still has OEM noise reduction and trunk mat. On that first car there is very little diff noise. On the second car (also at 150k miles) with an adequately functioning original differential (not rebuilt)....I used ECS bushings front and rear (88A durometer polyurethane and Black anodized 6061-T6 aluminum sleeve) I made this decision to use aftermarket bushings to save $100 and make the install easier. I recalled how shi##y of a job removing a destroyed front bushing is while working under the car without the ability to access the front bushing from the top of (a removed) subframe. So I took some risk and decided to same some money. Bad idea.
The ECS bushings produce absolutely obnoxious noise at speeds in excess of 60mph. It is literally painful to my ears. To keep things 'fair', I have replaced the brittle OEM under-set noise reduction material with two layers of 80mil butyl sound deadener and it does not help. I've put two layers in the forward part of the trunk as well.
I am pulling the diff and getting those bushings out. This time I'm going to hire help to sit in the car and take the transmission in/out of gear while I pull the bolts on driveshaft and axles. Getting up and down is a hell of a work out.
