My pan had to be repaired a couple years ago for a similar reason, they basically drilled out the threaded part of the oil pan, and put in a new threaded insert and sealed it. The diameter of the drain plug crush washer is bigger now. Drain plug itself is stock. Seems to be fine.
Stripped oil pan drain bolt thread
Yeah, my shop could have repaired the oil pan no problem had they been able to get the drain bolt to back out. That has been the issue needing to be overcome.Originally posted by Nate047 View PostMy pan had to be repaired a couple years ago for a similar reason, they basically drilled out the threaded part of the oil pan, and put in a new threaded insert and sealed it. The diameter of the drain plug crush washer is bigger now. Drain plug itself is stock. Seems to be fine.
Hey George, email sent over to you with photos of the oil pan.Originally posted by George Hill View Post
Sure, send me an email to [email protected]. I've got about (5) pans sitting on the shelf so I don't need anymore but I'd certainly take it on a science project for the board.
