Just change everything and be done with it. No telling how the POs drove the car.
The peace of mind is worth it and you can only regret not doing something.
Suspension and steering parts wear tests
I have seen many instances where a rubber bushing seemed fine, and you couldn't create a feeling of play, yet once replaced, the car, while driving, felt immensely better.
Feeling for play is a better diagnostic for bearings/ball joints.
I would just adopt a policy of replacing all rubber parts at this point in the cars' lives.
What KDawg said. Get it in the air and jiggle stuff. Play = bad. My control arms are still fine at 100k miles. My FCABs were still tight but actually started to harden up and newer bushings feel softer and more compliant.
Struts/shocks - When they leak or 50k miles depending on road conditions.
Springs - Never as long they are not rusty.
Control Arms - Check ball joints for play. You can jiggle the wheel or squeeze the joints with a large pair of pliers to look for play.
Bushings - RTAB 30k, FCAB 50k
No, I'm saying that at your mileage, I wouldn't replace ball joints. Unless you see that their boot is torn or feel play.
At 16-17 years old and 66k, I would replace all rubber (fcab, rtab, sway bushes, front mounts, rsms etc), but ball joints like endlnks, control arm ends, tie rods, I'd leave alone. If their rubber dust boots aren't torn, they should last well over 100k.
Struts/shocks - when they don't dampen anymore or when they leakOriginally posted by timpnw View PostNew board member here... go easy on me.
How do you know when it's time to replace...- the coil-over struts (or springs) on the front?
- the coil-over struts (or springs) on the rear?
- the control arms?
- the lower control arm bushings?
- other parts in those suspension kits sold by ecs and fcp?
I recently picked up a '06 66k mi which needs an alignment after adding new tires. What should I look for or replace in advance of the alignment? The obvious answer is everything, but there is nothing really obvious standing out to me while driving it other than a pull to the right at speed. That said I never owned or drove one that was new-ish.
Thanks in advance,
Tim
Springs - almost never unless they are rusty/broken
Control arms - when non-replaceable bushings/ball-joints are worn out
Front Control Arm Bushings (FCABs) and Rear Trailing Arm Bushings (RTABs) - more frequently than other suspension parts on these cars. Unless you have record of the ones on your car being replaced recently, you probably need new ones.
Get the car in the air and start pushing and pulling on things to look for any movement.
Definitely visual inspection first followed by any required maintenance first then alignment. Worn out tie rods can make alignment difficult to impossible on the front end. With the mileage you are at it will just depend on how the PO treated and maintained the car.Originally posted by timpnw View Postoceansize Thanks for the reply. Makes sense. While I do some DIY, I'm not going to do an alignment. Should I get an alignment since that's my immediate need and have that shop look for those things? Alternatively, should I put it up on jack stands at home first and have a look around with the wheels off?
For any bushing, ball joint, or mount a visual inspection should suffice. Cracking, flattening, and general condition should be noted. For ball joints excessive play shouldn't be present. Springs/shocks are bit tougher but bottoming out, odd tire wear, too much roll or bounce, etc.
- the control arms?
Thanks in advance,
TimTags: None
