Hi All,
I am following the TIS camshaft replacement doc and it says to move the crank 30 degrees against the direction of rotation before removing the camshaft (timing chain is removed at this point) because "No piston must be in the TDC position when the camshaft are removed".
Does anyone know why this is? There's no mention of this in DIYs
