I ask this question since I just read a post about the pinion seal was set a little too deep.
Most people when replacing the pinion seal, we just marked and tighten the pinion nut back to its original position when decided to keep the old crushed sleeve. But why a crush sleeve is needed in this case for preload 2 taper roller bearings? Why most front wheel bearings with the same taper bearing uses no crush sleeve?
To crush the new sleeve I would imagine it needs 60 ft lbs or more. When reuse the crushed sleeve and just tighten the nut to the original marking, I bet it takes much less. What harm can this cause?
I could preload the pinion bearing without using a sleeve (just like front wheel bearings in many older cars). What can go wrong with no sleeve?
