All, looking for some insight here. I fare much better when it comes to anything mechanical but admittedly struggle fully comprehending the electrical stuff.
2003 M3 race car
90k miles
New alternator (previous one died probably because of this issue)
Optima red battery
Started having issues about 3-4 seasons ago. Battery light would flicker on and off. Became sustained at the end of one season. Beginning of the next it was off but came back and remained.
New battery last year and kept it on trickle charge for any prolonged period in garage.
New alternator a few weeks ago and battery light went away.
Main battery negative ground in truck is solid and making clean contact with chassis.
Connections on alternator are solid and clean.
Two days at Watkins Glen, attached images are traces of voltage lap by lap.
Day one starts off from idle through lap one at 14 volts and starts to drop on lap two. It is then slightly erratic from 13.1 to 13.7
Day two starts off from idle through lap one at 13.9-14.1 and drops sharply on lap two and then ranges from 12.6 to 13.6
My friends identical M3 is extremely steady at 13.5-13.7
Could this be caused by bad grounds?
Would they be the main power terminals at alternator, starter, engine bay, etc.? I'll have to look up a diagram for more locations...
Could any interior wiring gone bad be causing this (not the cleanest interior stripping, there's some brown grounds that could be bad...)
Any other insight?
Much appreciated.
2003 M3 race car
90k miles
Optima red battery
Any other insight?
Much appreciated.
