Originally posted by bigjae46
CSL breather tube
Thanks, what do folks do with the electronic valve sensor that plugged into the stock vent hose? Not sure where to tuck that away if I don't want to completely unhook it from the ECU
Hi - I know this thread has gone quiet, but wondering what is best practice here. I have a 2005 and will start with modified CSL software (Terra). If I simply use the OEM CSL vent hose, should I be doing anything else here?Originally posted by Fresh1179 View PostGonna open this one back up. I’ve been running the OE configuration on my ‘06. Did we ever figure out if this would cause issues. CSL software. This has been killing me for a while because every time I look at it, I wonder if I have it all wrong…
Thanks, was being a tad coy with my question... 😁Originally posted by Slideways View Post
The two connectors (NORMA brand) that are at each end of the tube.
Wait which part do you keep?Originally posted by Sharocks View PostCut off the plastic hose, keep the ends, find a hose that's the right size and use hose clamp.
Cut off the plastic hose, keep the ends, find a hose that's the right size and use hose clamps.
Really easy.
Also, lol paying for this part.
Interesting idea... Now I wish I hadn't hacked mine in the first place!!Originally posted by SQ13 View PostYou could buy a stock line and use a heat gun to stretch it out.
Exactly what I'm looking to do and what I needed. Thank you!! 5/8" tubing on order!Originally posted by DoubleSidedTape View PostI have 5/8 tubing connected directly to the end fittings (so no corrugated section).
Does anyone know the ID dimension of the make shift vacuum line/fuel hose that can be used in place of the BMW CSL hose?
I have this part on order again after the first one showed up damaged, but it's looking like a mid to late June arrival and I need a workable solution before then. I'm worried this temporary nylon tubing I used just to get the car running will not hold up and I need to drive the car...
I want to say that 0.75" ID will work. The outside measurement of the corrugated section is 0.71" (18mm), but it balloons a bit larger at the plastic fittings (the 90° ones).
Edit: I could most certainly cut mine apart and measure the fitting, but don't want to do so in case I can't source the right size tubing. This "works" for now, but I'm not sure for how long it will.
Not really a solution but you could code out the DTC for "System test, crankcase breather"Originally posted by DoubleSidedTape View PostRelated question:
I am using the stock airbox, but I have an oil catch can that I had used on my 02 previously now hooked up to my 05. Is there an easy way to code out this valve or trick the car into thinking its there? I have no issues with vacuum leaks since I put a vacuum bung over the air rail but I am getting an error/CEL for "System test, crankcase breather"
Related question:
