Going to be pulling my rear diff soonish and doing an LSD build, but my axles are old and stuck in place so I need fresh ones. Where is the best place to get new/upgraded axles? Seems to be a crapshoot hunting down the right axles that aren't low quality junk.
Best place to get new axles?
I think I found in a thread on this forum, someone recommending these guys for a rebuild:
CVJ Axles remanufactured OEM cv axles, steering racks, MB air injection smog pumps, as well as racing and off-road parts.
I have no personal experience with them, but will need to do this same job in the near future. Subscribed.
Is it only the CV inside of the axle that can be rebuilt? Does the other side (splined side) need rebuilding as well?
I did see there is a CV joint rebuild kit, if it’s something you would want to DIY.
**edit I posted a link to an incorrect part. Removing so nobody orders it-**Last edited by L0okitzRaj; 07-23-2022, 07:54 AM.
That's for the driveshaft joint.Originally posted by SL Blak Soldier View PostIs it only the CV inside of the axle that can be rebuilt? Does the other side (splined side) need rebuilding as well?
https://www.turnermotorsport.com/p-5...hoCyhcQAvD_BwE
Burkhart sells an output shaft rebuild kit which is cheap, you'll need two:
They rebuild both sides of mine. It was around $300/axle.Originally posted by SL Blak Soldier View PostIs it only the CV inside of the axle that can be rebuilt? Does the other side (splined side) need rebuilding as well?
Oh shit. Good catch..Originally posted by jet_dogg View Post
https://burkhart-engineering.com/en/...-incl-csl-bmw/
And doublesidedtape... I emailed them yesterday to get some more info. thanks!
Just wanted to update, in case anyone is curious. They said ~$369 each/axle + shipping. with a few day turnaround. Both inside and outside cv joints.
people say you hear clicking.Originally posted by eacmen View PostSymptoms of failing axle CV? Other than grease flying out?
in my specific scenario I have play between the axle and hub and axle and diff, causing a clunking.Last edited by L0okitzRaj; 07-19-2022, 07:55 AM.
Awesome thank you. Gotta find a way to send mine out or get a spare set to send out.Originally posted by SL Blak Soldier View PostJust wanted to update, in case anyone is curious. They said ~$369 each/axle + shipping. with a few day turnaround. Both inside and outside cv joints.
in my specific scenario I have play between the axle and hub and axle and diff, causing a clunking.Instagram: @logicalconclusion
Isn't a certain amount of lash expected there? I've had axles rebuilt by "Axles Unlimited" that still had that play, I'm curious to hear if CVJ is able to remove it.Originally posted by SL Blak Soldier View Postin my specific scenario I have play between the axle and hub and axle and diff, causing a clunking.
Does repairing the outside portion require anything special tool wise that the inner does not? I would just rebuild myself but it appears none of these outfits sell outer portion repair parts.
I would send them out as well but sending to the UK would cost enough that I think this might have to be a DIY deal if parts can be souced. Mine are both just starting to sling a tiny bit of liquefied grease around onto the SF after a drive.
This winter I want to swap my 4.10s for maybe a 3.85 case and getting the axles refurbished would be a good thing to do as well.2004 Silbergrau Metallic 6MT
I don't think the outer CV joints require anything special. I just don't believe there are any parts kits, as you stated. Who were you going to send it to in the UK? ...CVJ is located in Colorado.Originally posted by Cubieman View PostDoes repairing the outside portion require anything special tool wise that the inner does not? I would just rebuild myself but it appears none of these outfits sell outer portion repair parts.
I'm sure there is definitely a certain amount of play to be expected. Mine are pretty audible on both ends, causing a loud clunk in addition to the normal m, differential clunk.Originally posted by Pklauser View Post
My car also has 200k with plenty of clutch drops on 275s to wear them out. So either way, it's time for a rebuild!
Ah, I thought Burkhart was rebuilding them until I read the first post.Originally posted by SL Blak Soldier View Post
