Car sat over night and today, tried to start it. No crank. After about 3 attempts it started. I also been having a problem on hot days . it won't start until after a couple tries. Any ideas where I should start looking for the problem. It's a 6speed.
No start when warm
It could be the ignition switch contacts dirty/pitted. Next time when it happen no crank, pull the EWS with connector and check if pin2 have 12v when key turned to START. There are 3 large pins on one side of the connector, the 2nd from the edge. Do this with EWS and connector plugged in, if EWS is unplugged then there is no load and a bad switch contact can have a perfect 12v with no load.
I would remove the switch, disassemble and clean up all the contacts using the back 90* edge of a Xacto knife.
