Originally posted by Subfra///Me
Alternator Options
Originally posted by AWE46M3 View PostBought a Valeo alt in December on Bimmerworld when it was on sale. Installed it last week when my Bosch alt voltage regulator started to fail causing some electrical gremlins to pop up in the car. The Valeo alt started whining as soon as I pulled out of my shops parking lot. My car sounded supercharged...
Purchasing an OEM BMW alternator through my shop and having them install it again. I get a 2 year warranty on the alternator and don't have to pay for labor again. It seems like Valeo and Bosch reman alternators are super hit or miss and it's the luck of the draw you'll get one that works. Paying the OEM tax and going the BMW route with this part.
On a side note, why are people interested in using any other alternator than the one specifically made for the e46 M3? What are the advantages?Last edited by Subfra///Me; 06-21-2023, 07:44 AM.
Funny enough, the M3 has a molded intake port on the brake duct that has been blocked off. That could have been for alternator ducting.
I was thinking about running. 200amp HO alternator in my 330ci to power a massive 25wattsx2 amp that was 44” long. Yup…that amp had unregulated power supplies and was stable to a 1/4 ohm. Almost a short circuit! But I would have needed cooling to run that alternator.
Ultimately I decided to go with more efficient amps.
A lot of the non-M guys have used the BSD alternators on their pre-BSD cars with seemingly no ill effect. I don't know if those voltage regulators just fall back to the old school mode or what.
I just heard from my tech and he said it'll fit but the plug functionality will not work as it uses BSD communication. So it's better we stick to the 140Amp. I really wanted to get the Z4M alternator lol
Yes, I'd only go with an E46 alternator. I thought the Z4M one could be used in a pinch due to the mounting points being the same but forgot about the BSD functionality.
It will as the mount on the S54 is the same for both cars. Z4M is 150A while the E46 is 120A.
Originally posted by 0-60motorsports View PostAnyone know if the Z4M alternator will fit on our M3's? Especially the electrical connector( I guess if we change the back cover)?
Edit: Z4M also has a different connector due to BSD comms.Last edited by Slideways; 06-19-2023, 03:26 AM.
The problem might be the oil cooler lines it might interfere with the duction maybe not.
...That might actually be that mystery solved. I always wondered what that was for. Sure looks like the alternator ducting would fit there
