BBS Fitment Question
    I’m looking at snagging a set of wheels that are the following sizes. Will 18x8.5 ET15 and 18x9.5 ET22 fit our cars? Been searching but can’t seem to find anything Specific to the e46 M3
    996TT
    Turbo E36 M3
    FZJ80
    I would say that would fit no problem with a bit of camber on the front. The rear is an easy fit, common size.
      IIRC most 8.5" wide BBS front wheels for E46 are in the ET32-38 mm range.
      WAG but sounds like wheels that are meant for an E39. Double check the center bores are 72.6, not 74.1.
        Just based on those specs, should fit no problem with the proper suspension. Some people even go 18x10 and sometimes 18x10.5/11 with an aggressive offset. But yeah, definitely double check the center bores.
          Fronts will need a tad bit of camber but nothing crazy.
          Rears will fit fine.
          2004 Dinan S3-R M3
          2023 X3M Competition
            Thanks everyone, I’ll confirm the center bore
            996TT
            Turbo E36 M3
            FZJ80
              You can run a 74 center bore wheel. I run a 75
                You *can* but there are plenty of hub centric ring adapters available. Sooo
                '01 M3, Imola/black
                  I would not run that offset up front.
                    Front offset is garbage. Don't waste your money.
                    2005 BMW ///M3
                    Black6MT Daily
                      It'd be like running a 30mm spacer on a normal front wheel. Thoughts and prayers for your original wheel bearings.
                        I appreciate the advice everyone, I’ll pass on them and stick with wheels that have safe/traditional specs
                        996TT
                        Turbo E36 M3
                        FZJ80
                          This is 8.5 +20 for reference
                          2004 Dinan S3-R M3
