Weird SMG Light only at initial startup and driving?
    Took the car out and this has been happening the last few times. I will get the SMG light come on at initial startup and driving. It's showing a generic "Clutch Control" code. After driving for a few minutes, turning off the car and restarting will get rid of the light and the car will drive for the rest of the drive (can be hours) with no light returning. Even with the light, it was driving perfectly. Anyone else experience this? Thanks. Car has had seals, motor and accumulator replaced and is relocated.
    Do you have a smell of clutch burn?
    Might be a going out clutch slave cylinder..
    Check your smg fluid level.
      I'll check those. Thank you. No smell of any clutch burn and it appears to be shifting fine. Just can't figure out why the problem occurs only when cold/initial start. This is the opposite of problems from overheating that most SMG have, ironically my car now drives better as it gets hotter!
