I’m having issues fitting my rotors on my new brake shoes. I’ve adjusted them to the tightest setting and nothing. I’m using the PAGID brand (p/n: 355050471). Anyone ever have this issue before?
Brake Shoe issue
Originally posted by Estoril View PostDid you push the caliper piston back all the way? Are the pad 'ears' fully seated?
Parking brake is down. But idk man, this has been a PITA. I haven’t done the driver side yet.Originally posted by eacmen View PostDumb question but parking brake lever is down, right?
Same issue on both sides?
Could parking brake cable be stuck and not releasing?
I am writing this from my phone on my boat the water, so I can't see the video very clearly.
But I am pretty sure you have the shoes upside down.
In my photo's I have from when I did this I have the larger circular holes on the bottom with the expander and the big spring, and the smaller more rectangular holes at the top with the adjuster and the small spring.
Also do not forget to fully slacken the adjustment nuts under the lever in the cabin.
Hope that helps.E46 ///M3 • 12/2002 • phönix-gelb • 6MT
Originally posted by bmwfnatic View PostI am writing this from my phone on my boat the water, so I can't see the video very clearly.
Hope that helps.
- Likes 4
Is this what you’re saying?Originally posted by bmwfnatic View PostI am writing this from my phone on my boat the water, so I can't see the video very clearly.
Hope that helps.2 PhotosLast edited by Mattn1192; 08-13-2022, 01:33 PM.
Yes, that was what I was saying, because that is how the holes are on the genuine part, and many others.Originally posted by Mattn1192 View Post
However, it seems yours are flipped, and the holes aren't anything to go by in this case.
So as for orientation, how it was before, is correct for these shoes, so it seems.
You didn't mention before, what kind of disc are you using?
