Originally posted by fattycharged
i would highly suggest you give some thought before bidding. there are things bidders should be aware of when dealing with swapped cars of this nature. might look pretty on the outside but need to be aware of the potentials first.
they chose the oldest /hardest e46 chassis to start with. the 323 which started out life as a mechanical throttle pedal. this means they had to add the 6 wires for the electronic throttle pedal to the body hardness to run to the DME box to connect into x60004 dme connector. they still have the original PACMAN Round diagnostic connector under the hood which means any time you want to connect to a module in the car other than the DME, you need a Round DIAG to rectangle OBD2 connector conversion pigtail unless you bridge 2 pins in the round connector to route diagnostic signal back to the OBD2 port under the dash which currently only supports emissions communication and basic Diagnostic tool generic P code read out.
everything in the car is going to be old ad not updated. if you want to add a blue bus for example, the connector in the back normally reserved for the factory Bluetooth module that you use for bluebus, will need a conversion harness. it wont have CD changer or ibus capabilities out of the box and need conversion harnesses.
the wiring that had to be done in the DME box will be much more hacked as the body harness electronics in the DME bod was different on 323 cars and 325 and above DME box power connections needed to be added.to bring it up to M3 engine harness connection specs.
323 cars never came with the updated Heated DMTL or DMTL canister in the back. most people code that functionality out but if you want to get BARd... you will need that retrofitted in and wired into the car all the way up to the DME box.
in the comments the seller mentioned that they tried to get BARd and failed because of the CAL CVN and CAL ID mismatch... well this is because they are running a modified TUNE file to delete EWS and most likely a host of other codes coded out to resolve CELs for emissions options that are not present. They dont realize that they actually need EWS present and they need a stock UNtouched factory 6MT file flashed via WINKFP to the DME and they are using a DME that was in an SMG car so they most likely used software to change it to 6MT and delete EWS and rear O2s etc....
retrofitting MK6o will be a nightmare. - you will need to replace brake lines, remove the MK20 Charge pump and replace the Master cylinder, brake booster, booster vac line to the Air rail, and create a retrofit MK60 harness to bring over the connector to the driver side annd add in the DSC/Yaw sensor under the seat. lots of wiring and will require removing the dash and carpet to do it cleanly.
also the car is so old that when you use programs like INPA or NCS Expert etc... you will have issues coding defaults in modules. this wagon has a win with AR33 in it which means it uses the older SA and not the newer VO language so if you want to code defaults for your GM5 module or Airbag module or any other non M3 module... when you go to read the SA... you will have to read the EWS module. and thats if they didnt swap in the M3 EWS module like some people try to do to get around EWS delete.. if you read the Cluster it will fail and say it has a VIN mismatch as well as doent contain SA... the cluster contains the newer VO language.
im sure the car runs fine and most things work but with as many things that have the be hacked or changed or rewired to get things "right" it becomes a real mess if you ever need to go clean up something or take it to a shop and have them diagnose something or if you are DIYing and didnt build the car yourself.. now you are trying to figure out if your issue is related to something new or is it related to something with the swap or is it related to something done wrong with the swap etc...
ive done many S54 swaps and also a few of these 323 specific swaps myself and its hard to get the car "right" there are so many unknowns with a swap car especially on an older chassis like this and for a crowd like BAT where many people that buy the car need/want/expect a car to just work.
for the DSC, like george said, its best to just get the M3 MK20 DSC module and replace the 323 MK20 module and be done but theres a caveat... when you install it, you will need to update the VIN in it to match the Cluster and the Steering angle sensor... if you install the module in the car and try to code it, NCS expert or ISTA will bark at you and tell you the module doesnt match parameters because its expecting the 323 non M module not the M3 MK20 module. you will need to use PAsoft/bmw scanner to change the VIN since it doesnt care like the other BMW apps do.
sorry for the info dump but its a lot going on and anyone who buys that car needs to be well informed of what to expect before a purchase.
The car has an MK20, MK20s have all 6 lines entering the block on one side, MK60 is 4 and 2.
