Hey gents.
So I parked my car two years ago after some minor clutch issues came up and haven't had time to circle back to it until today. Its sadly been untouched since then. I threw in a new battery, 8 gallons of fresh gas (was nearly empty), checked all fluids, and tried to get it running. Car cranks well but does not want to start. Managed to get it going for a few seconds with some starter fluid in the air filter housing but no luck beyond that.
New fuel pump was installed about a year before I parked the car (so 3ish years) and has about 20-25k miles on it. I know these go bad when they sit for an extended period of time (internal check valve X moisture, or otherwise), but the pump primes very audibly. I removed the rear seat, checked connections, gave it a few small hits of a mallet, and even pulled the attached fuel hose/line under crank for a split second to confirm that fuel is getting to, and/or through, the pump. Fuses check out okay. Haven't checked the relay but seems thats not my issue. Also fiddled with the fuel sender for shits and giggles (which for some reason, when unplugged, still gives me a fuel reading on the cluster?).
I have strong spark to the plugs, which I replaced today as well, but it seems they are not getting any fuel. Haven't checked fuel pressure from the engine bay because I don't see a schrader valve anywhere.
So what gives? Do I have a compromised pump that can't get fuel to the engine? Or am I missing something here? Figured I would touch base with the boys before throwing another one in. Appreciate any insight. Thank you in advance.
