  • 9kracing
    It would be amazing if someone that installed these took pics and posted a writeup of how they did it for the rest of us slobs
  • PSUEng
    Originally posted by mthird View Post
    NO NEED TO REMOVE RIVET AND THE BRACKET ! JUST PULL OLD RUBBER OUT, SPRAY WD-40 AND SLIDE NEW STRIP IN.
    I'll try that method when I do the other side. The side I did do, there was no way the new rubber was going in there as far as I could see; but, I'll give your method a try.
  • E46 M3
    Mine "arrived" today but post office has lost it lmao just my luck, hopefully it turns up tomorrow.
  • mthird
  • PSUEng
    Originally posted by Mayan-Viking View Post
    This is exactly how I feel.
    Well you just drill out the rivet. I bought a Quinn rivet gun and rivet pack from harbor freight--1/8" Aluminum rivet back in, no problem. The issue is, seating the bracket. That bracket allows the finisher to attach to the body. Anyway, it's not THAT bad, it's just finicky. Make sure you line up your new seal to the tick mark in the trim finisher and stretch it to fit; hotter is better. And put a new foam seal over the riveted area to keep your paint from getting scraped by the bracket upon reassembly.
  • Mayan-Viking
    Still scared to install mine bc of this rivet issue. And it’s like 105° here 😭
  • nachizl8
    Got it thanks
  • Maxima SE
    Originally posted by nachizl8 View Post
    Maybe a dumb question but does this rivet issue not come up if you choose to install the OP aftermarket weather stripping option? Is this something that’s only encountered with this OE style weather stripping?
    No. The aftermarket stuff is just some generic weatherstripping that is forced into place, especially around the rivet area. It is kind of a ghetto solution to be honest. I do not remember seeing a rivet but it has been well over 3 years since I did the aftermarket fix. The install for the OEM one gotta be different.
  • nachizl8
  • SQ13
  • 9kracing
    FWIW mine showed up awhile ago, looks good, if it's not OEM it could certainly pass for it.
    Seems to be very good quality. When I install them I will post a pic.
  • gmanM3
    Had to sign up for an account to this forum just for this. In for 2 sets!
  • PSUEng
    Strange, when I did my 3M weather stripping I definitely didn't have any rivets to deal with, just screws, the trim pieces came off fairly easily.
    I also don't think any of the previous owners had taken the trim off as the weather stripping was in bad shape.
    The rivet fastens a bracket to the aluminum finisher to allow the finisher to attach to the body and probably provide some degree of seal position control. The way the bracket fits is such that there is an interference with the rubber seal making it tough to position into place with a new seal. I’m still wondering if there wasn’t a better design—like integrate the bracket shape and mounting points into the aluminum trim and make some shape change on the rubber seal if necessary . Here are some photos of the area…
  • Cubieman
  • E46 M3
    Maybe this is why BMW never sold it?
