I used the 3M, bought it off eBay. See post 1 to see everything I’ve seen people say they have used.
I'm having the exact same issue with the Metro weatherstripping. Vacuum line didn't help. Any other weatherstripping that is recommended that can be ordered online?Originally posted by andyitslit View PostDid my driver side this past weekend with the Metro weatherstripping. I got a big kink but I'll go back in and stick some vacuum line in there.
I did this a long time ago on my old E46 and it turned out much better but no way I remember which weatherstripping I used. The metro one seemed too soft.
YES, I am JUST in the middle of planning this fix on my drivers side window. Thanks OP.
This should be added to the DIY thread, if not already.
Cheers everybody!
Big thanks to this thread as well as the video references mentioned. Just tackled this last week, plastic razor blades definitely make the job so much easier. I used Adam's TAR to remove the adhesive which worked like a charm: https://adamspolishes.com/products/adams-tar
