Prior owner installed UUC rear camber arms but used the BMW eccentric bolts at the outer location. I am replacing bushings and plan to replace the upper and lower outer ball joints and want to replace the corroded bolts but don't need the eccentric bolts due to having adjustable camber arms and don't want to spend the $$$ on BMW branded bolts if not needed. I think M12 x 1.5 x100mm (this is what the upper bolt is so would probably work in the lower spot) would work not sure where to source those. Anyone use replacement hardware on the outer control arm locations that it's BMW branded but same class 10.9? If so where did you source them. Thanks
Rear camber arm hardware replacement
