The obvious question is why all differentials have plays in the spider and side-gears, regardless open or LSD units? Why the factory didn't just have a cheap spring washer? I notice that the spiders rotate around a rod with flat machined on the rod under the spiders. The flat must be for oil to easily get in between. So spider rod wear is a big concern for the engineers.
Here is what I think: the plays or clearance in the spider and side-gears is needed so the spiders don't constantly press on the rod at same place, and the nature of the car being driven, there is no constant pressing of spider to the same spot on the rod.
Now come the clunk eliminator spring washer. It causes the spiders constantly press hard on the rod (the spring loaded side-gear pushes on the spiders against the rod), at the same spot. I think the rod will wear much faster in this case.
A better way to eliminate the clunk is to use flat shims and leave some plays in the spiders and side gears, for oil lubrication.
