LSD Diff clutch pack second source?
    Is this only true for LSD that has the Belleville shim on the clutch stack? The stock LSD without the spring shim should not push on the end cap the whole way, especially with worn down clutches.
    There has been tension in everyone I’ve opened and assembled so far. You’d have to wear the clutches down so they are wafer thin to lose tension internally.
      Got it. So I think the locking shear pump piston is spring loaded.
