Driftworks puts some... cool, but ultimately stupid, headers on their s85 e46
Interesting wagon. But the question is still why? What does it bring, other than noise, that a far easier and less costly V8 doesn’t achieve? Don’t get me wrong I do understand cool factor and being able to say I did that but outside of that I don’t see the reason given the difficulty and cost. Because let’s face it most aren’t going to DIY this. Congratulations to that dude by the way. I’m sure he loves it.
Kind of the same reason you'd want to swap an S54 into an E30 M3. Sending the direct descendant and evolution of BMW's NA M bloodline into a time machine to live in an older golden era chassis is a nice dream to have and possibly achieve.Last edited by EthanolTurbo; 10-07-2022, 03:49 PM.Instagram: @logicalconclusion
- Likes 3
I’ll admit I would never pay for an S85 swap unless there was a built kit that is proven to work. I’m not skilled enough to do the work myself, and I wouldnt trust any shop around here to do it right. BUT if one happens to show up for sale, I would definitely consider a turn key S85 E46!
If the S54 ever grenades in our track car its either getting another S54 or an LSx.
Boy, I would just settle for an E60 M5 at this point.
For years I thought negatively of the looks and believed the S85 to be a ticking time bomb but after being around them, driving them and realizing the maintenance isn't that bad I do want to own one.
I'd even settle for a non-LCI SMG in black sapphire, I can't shake the thought. If it weren't for my buddy having 2 of them I would still think negatively of the platform, it's just unfortunate how little aftermarket support for these there is, we have it lucky in that regard with the E46 M3.2004 Silbergrau Metallic 6MT
Originally posted by Cubieman View PostBoy, I would just settle for an E60 M5 at this point.
My experience has been extensive in just over a year. I’ve put 27,000km on it. It’s my daily.
After doing bearings, fuel system, throttle actuators, idle control actuators, oil cooler, voltage regulator and radiator fan.
It’s been somewhat reliable *grins*
It is at about 560 PS with ID header, intakes and stage 3 tune. It's low 8s 100-200 kph and its true power is above that.
The latest lightweight flywheel and carbon driveshaft has made the SMG3 enjoyable - all across the range. No more jerks & clunks at low speed, the downsides are non existent. It’s fast & precise and S6 at WOT is better than ever. The steering rack is probably best ever for an M, and the B16 EDC + Dinan sway bar kit has made it feel below its weight.
It can also look pretty damn good with a few aesthetic changes like LCI retrofit, 20" fitted wheels and gloss black accents, including the mirror pillar trim. The pre LCI interior is meh, and it's expensive to upgrade: carbon trims, steering wheel, LCI door cards, CIC retrofit - ouch.
That's lot of $ to bring it up to par dynamically and aesthetically while paying 2.00$/l doing 250km between fill ups. I still wouldn't have an E90 M3 over this for the driving dynamics - for costs, that's up to you.
It's stupidly expensive to keep on the road, and its still relatively worthless considering - but the experience is invaluable. Nothing like toasting your latest 911s with groceries in the back sounding like an F1 car.
- Likes 3
This makes me smile. They are one of the greatest M cars ever made with the right maintenance package, and mods. Buy one while we still can run these cars legally.
The latest lightweight flywheel and carbon driveshaft has made the SMG3 enjoyable - all across the range. No more jerks & clunks at low speed, the downsides are fast & precise and S6 at WOT is better than ever. The steering rack is probably best ever for an M, and the B16 EDC + Dinan sway bar kit has made it feel below its weight.
- Likes 3
Originally posted by eacmen View PostI’ll admit I would never pay for an S85 swap unless there was a built kit that is proven to work. I’m not skilled enough to do the work myself, and I wouldnt trust any shop around here to do it right. BUT if one happens to show up for sale, I would definitely consider a turn key S85 E46!
From a hardware perspective, I think a dry sump would make fitting the steering column WAY easier. I just wish I could easily fit a 5 speed to keep the weight down.
Still not cheap though...
$6k to $8k - S85 w/ECU
$2k - S65 6 speed
$8k - Dry sump
$2k - Rod bearings and TAs
$2k - Exhaust
$2k - Other stuff
Originally posted by bigjae46 View Post$6k to $8k - S85 w/ECU
$2k - S65 6 speed
$8k - Dry sump
$2k - Exhaust
$2k - Other stuff
Coolant cooling system
Oil Cooling system
Clutch/Flywheel
Shifter
Driveshaft
Tune
Intakes
Headers/steering shaft modification
Fuel System
Email to [email protected]
Even for a track car I think your prices are a bit low.
Oil Cooling system
Clutch/Flywheel
Shifter
Driveshaft
Tune
Intakes
Fuel System
Engine cooling - not sure???
Oil cooling - already have a custom SS braided lines. If I went dry sump then this would already be factored in.
Clutch/Flywheel - reuse OE?
Shifter - not sure
Driveshaft - $650 to modify an OE driveshaft, balance and replace consumables
Tune - just use a stock ECU and tune
Intake/exhaust/headers/steering - custom. I’d try a Z4 rack with the EPAS on the steering shaft
Fuel system - I’d use the radium kit with a Walbro pump
let me know what you think…
Shifter - not sure
Oil Cooling - S85 OFH is on the passenger side, if you go dry sump I don't know enough about the options here, but a quick google search showed a VAC kit for $6100 and a kit from Carbahn for $7k. You'll still need lines, a tank, etc. I think $8k might get it done, but maybe not.
Clutch - Doing all this and going to put a stock clutch/flywheel in it?
Shifter - Will be custom, there isn't an option that works off the shelf that I have found (with the trans mounted using a stock crossmember).
Tune - Stock DME is going to have a bunch of warning lights on due to missing components.
Intake/exhaust/headers/steering - custom. I’d try a Z4 rack with the EPAS on the steering shaft - that all factored into your $4k exh/misc budget?
Fuel system - The MSS65 DME uses an EKPS to control the fuel pump which IIRC is 3 phase... As far as I know there is not a 12v fuel pump output to control your walbro pump.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Engine Cooling - S85 has a dual system in that the radiator is actually two rads in one... 2 inlets, 2 outlets.
But my numbers do seem low now. I know that cams, tune, and other stuff are needed for the full V10 wail. How would wiring the fuel system work? That sounds like a PIA.
Right now, I'm happy with my car as is although the exhaust note is not exactly pleasing. But it is loud!!!
