Anyone used the Rogue Engineering clutch kit with lightweight flywheel (10lb aluminum or 13 lb steel)? I'm going to upgrade the stock clutch and dual mass flywheel preventatively and really want a lightweight flywheel for performance reasons. Has anyone used this clutch kit and has input on how the overall experience and chatter? Thanks!
Rogue Engineering clutch kit and lightweight flywheel
Definitely not a daily anymore. Just can't decide between the 10 lb aluminum or the 13 lb steel. I want as much performance as possible for the track but also to be enjoyable on the street, sometimes too light of a flywheel makes shifting more of a hassle just driving around. But at this point the stock clutch and dual mass are really holding back the performance and enjoyability vs how it should feel with a single mass and more direct clutch without the self adjusting component.Originally posted by Syfon View PostI have a jb racing lightweight aluminium flyhweel. Rattles like a box of bolts (neutral, clutch out). If you daily your car and want to keep it quiet and reserved, stick with the oe dmf. Otherwise go with a lightweight smf. I love mine - motor revs like a bike engine!
I also have a sneaking suspicion that my clutch is going to die soon and has lived a very long life.Last edited by EthanolTurbo; 10-11-2022, 10:50 PM.Instagram: @logicalconclusion
EthanolTurbo take a look at the TTV industries one they also have a clutch for it.
Specifications Made in England OE+ design: Designed to bolt to OEM clutch Compatible with OE starter Installed using Genuine BMW bolts CNC machined from a forged high carbon steel billet Dynamically balanced by TTV from the factory Fitment for MT and SMG2 Weight: Single mass: 5.3 kg / 11.6 lbs OEM: 10.97 kg / 24.2 lbs
Go the 10lb aluminium flywheel. Less unsprung mass makes a massive difference.Originally posted by EthanolTurbo View Post
Imho, the lightweight aluminium flywheel doesn't make shifting/rev-matching a hassle at all. Makes it more enjoyable in my books
- Likes 2
