seat cover options
    seat cover options
    Anyone recommend a good source for replacement seat covers? OEM ones are available but for around $1000 per peice, I would be looking at around $4000 USD just to do the front seats.
    Just have black leather so hopefully not to hard to find a color match. Although I might consider a different color and do the rears as well. I know of Lseat and riddies but no idea which would be a better quality. Any other options?
    Also, would the sport seat covers fit the m3 seats? Riddies seems to have better options but only offer a msport seat.
    Thanks.
    I have seen good results from LSeat on Porsches and Mercedes.
    But, because you have standard black leather, it might make sense to look for a pair of used/replacement seats. The swap is very straightforward and you might even manage to pick up lumbar support and adjustable bolsters, if you don’t have those already.
      Bmwrestoredseats on instagram is an option.
        Does he do made to order or does he keep a stock?
        I had a look at Gahh as well, about three times the cost of Riddies or Lseat bus still half the cost of OEM. Are they worth it?
        And I would not mind going with a set of used seats, but where I rarely see M3 interiors for sale and when I do the are just as worn.
          Porsche guys like GAHH as well. LSeat is quality though.
          another option is World Upholstery in Seal Beach(?). Got a set of replacement headrest covers for my 71 911 from them and was very pleased with the fit and quality. Suspect they source from the same place as LSeat, though that’s just a hunch.
            I might try Lseat then. Just want to refresh the interior a bit. Rear seats are pretty mint.
            Should order some replacement foam as well? I imagine 21 year old foam will turn to dust if disturbed.
              I've have Ridies on my NSX but the option they offer will NOT fit your M3. How bad are your covers now? Possible to get them repaired?Click image for larger version
                They are not super bad, no tears or rips. A few cracks and scuffs. But trying to refresh the car a bit.
