245/35r19f & 275/30r19r vs. 265/30r19 squared [Squared rear ZCPs]
    Yes, way better setup IMO running a 265 square setup. Lots more grip in the front. if you haven't experienced driving a square setup, try it out! I feel like there is so much more grip in the front i can learn to load up the front tires better.
    In one of my most recent setups, i went from 245/275 staggered ZCP setup to a 275 squared ZCP rear, and i feel like i'm learning the front limits of the car a bit more.
    PS - the I've cracked and bent my ZCPs before - so, i wouldn't recommend driving too hard on them...
      Yea I'm running -3.5 up front and -2.5 in the rear.
      Car actually is setup really well for these wheels but they are big.
      For reference, I use the same alignment setup for my 17x10 setup running 275/40/17 square.
      0 toe front and rear? Might have to rip your alignment when I get my suspension dialed in. Don’t really want to buy any other tires than 265/35 squared at this point if it’s doable.
        275/30 squared? Now that’s impressive…over -3.5 up front?
        I daily my car in LA so very worried about that. Will have to be vigilant about potholes.
          Yes 0 toe F/R.
          I've run 275/35/19 square before, it's too much tire and it's even heavier up front.
          I would stay at a max of a 265 up front since you're running 19's.
          I once ran 285 square and all it did was push lol
          2005 BMW ///M3
          Black6MT Daily
            275/30/19 square Indy Firehawk,
            15mm (or 18, i can't remember) spacer in the rear.
            shaved/rolled fenders front/rear.
            13.5F / 13.75 R ride height.
            2.8 Front camber,
            front toe is at 0
            rear toe is at .1
            Car isn't really low, but fitment is really on point so I think that's how i'm able to get away with the look.
