I'm close to ordering 288/280 12.5mm lift cams for my S54, probably go with Schrick but I can't find a definitive answer on whether 12.5mm lift will have sufficient clearance from the stock pistons or if I'll have to machine the valve pockets a little deeper.
I've read "there is lots of clearance" to "it's not worth the risk".
Does someone with these cams installed have a solid answer?
Thanks
Thanks
