Hi everyone, long time lurker to this forum but just signed up for an account hoping to get some guidance for my 2003 e46 M3 vert SMG to manual conversion.
I have had a hunting or surging idle ever since I bought this car about a year ago. It seems to idle kind of high (around 900 which I hear is fairly normal for this car) but will surge up to 1200 and then bog down to 4-500. On rare occasions the car will occasionally stall. I can prevent this by blipping the gas when I feel the RPMs getting too low. No issues otherwise, power seems to be all there. I have taken the car to 2 mechanics who are stumped. It has has had a smoke test (negative for leaks), throttle bodies cleaned, ICV cleaned and then subsequently replaced, new TPS, fuel pump and filter checked, and spark plugs replaced.
There is one code that keeps coming back in the DME immediately after clearing:
Fault code 80 schalterkette kraftschluss which I understand is related to the clutch position sensor.
I checked at the clutch pedal and it looks like I do have the brown clutch position sensor with part number ending in 700.
The wiring looks ok too based on some of the SMG to manual guides on this site with a wire going into connector/pin 20 on the DME.
Also, I confirmed the correct operation of the switch in INPA. (status grip switch off with clutch out and on with the clutch in).
Would it be worthwhile to replace the clutch position sensor even though it is functioning normally according to INPA? Any other ideas or further guidance?
Thanks everyone in advance for any help!
