With so many modern cars running LEDs or laser lights (not to mention modern SUVs having insane ride heights - pretty sure the headlights on the new Escalade are 1+ft above my roofline), driving the E46 at night and looking in my side view mirrors results in me being nearly blinded. Has anyone managed to install auto-dimming side view mirrors? Would love to do this resto-mod, but before winging it myself, wanted to see if anyone else has gone down this path.
Auto-dimming side view mirrors?
Can’t find the thread but I remember reading (on this forum I think) that someone did this successfully. By using the glass from another model and running wires from the interior mirror to the doors.E46 ///M3 • 12/2002 • phönix-gelb • 6MT
E39 M5 comes with them iirc2003 E46 M3 TiAg/Cinnamon 6MT
2005 E46 330i ZHP Imola/Sand
Instagram:@thegenius46m
I'm guessing that you have the stock blue mirrors and are still being blinded - or do you have the less expensive regular glass on your mirrors? I ask because my driver-side blue mirror was starting to corrode as they typically do, and long story, I ended up having a clear glass replacement mirror installed instead of the blue glass. I still cannot stand how much this clear glass blinds me compared to the blue glass that came stock on the car. I thought to mention this in case you don't have blue glass; it might be worth giving that a try before going all out
I did it on mine.
You need pre LCI e9x mirror glass. It's same exact shape as E46 M3 glass and has heat and electro chromatic
I made 2 independent wiring harnesses for the left and the right side and I ran new wiring through the door harness connector and then from the door harness connector when it up to a pillar to the headliner and wired it into the auto dimming module of the mirror.
The electrochromatic wiring is the same as E39 and e53 and e9x purple and black.
- Likes 5
The electrochromatic wiring is the same as E39 and e53 and e9x purple and black.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - CSL Lip - Gruppe M CF Intake - Supersprint - M Track Mode
Originally posted by ChapterM3 View PostI'm guessing that you have the stock blue mirrors and are still being blinded - or do you have the less expensive regular glass on your mirrors? I ask because my driver-side blue mirror was starting to corrode as they typically do, and long story, I ended up having a clear glass replacement mirror installed instead of the blue glass. I still cannot stand how much this clear glass blinds me compared to the blue glass that came stock on the car. I thought to mention this in case you don't have blue glass; it might be worth giving that a try before going all out
That is amazing the LCI e9x mirrors fit! I'll echo what everyone else is saying - if you're able to confirm part #s and wiring specifics, it's greatly appreciated. No worries if not though, knowing someone else has accomplished this is fantastic news.
This is a cool conversion, I'm going to give it a try as a winter project on Rosso. Looks like these would be the mirror part #'s:
US Version:
Left 51167144309
Right 51167144306
Euro Version with Blind Spot:
Left 51167144303
Right 51167144304
Will probably go with the Euro version. Still researching the wiring harness but went ahead and picked up a used one off eBay with the correct mirror plugs. Will figure out the rest when I get it apart... Ultimetly I'll create my own harness with only the required wires and needed plugs for final install.
More good info in this thread.
- Likes 3
