Recently got a loud grinding noise coming from my front right brakes when braking. Popped the wheel off to investigate, and found that the inner pad was worn down to the metal, which was scraping the rotor. Interestingly, the outer pad has *tons* of life left, as do the brakes in the other three corners. FWIW this is a drilled BMW ZCP front rotor with BMW ZCP pads.
I'm wondering what would cause this? Bad caliper? Or maybe just improperly bled? I'm replacing the rotor and pads, but want to make sure I address the root cause so it doesn't happen again. How should I go about further diagnosis?
