Was driving today hit a hard bump. About 15 seconds later , the check engine light came on. Car running rough, with lack of power. Hit another bump check engine light came off, car ran smooth. I scanned for codes and got cylinder 5 misfire, that was a stored code.. So im thinking when I hit the bump it knocked something loose. Where should I start checking?
Check engine light, after hitting bump
Just change the bad coil, and save the old plugs if their tips are not worn down with "rounded" tips -- save $ and material.Originally posted by M3powerzz View PostCheck connection of coils, all is intact. Switch cylinder 5 coil pack with cylinder 1. Still rough idle, drove car until the check engine light came on. Misfire cylinder 1. So the coil pack went out. So im going to change the coils and spark plugs.
