Driver Airbag
    Driver Airbag
    Does anyone have the TIS for driver side airbag recall?
    I’m looking to buy a used steering wheel, so I’m just trying to figure out if the airbag has been recalled, replaced, or not affected by the recall.
    Thanks
    Just some old shitty cars.
    Get the last 7 of the VIN from the donor car. That's the how you tell. There have a lot of airbag recalls on the E46. That car could've been through 6 recalls. The only way to tell is to check ISTA and if the most recent was closed out.
      Recall doc:
      https://static.nhtsa.gov/odi/rcl/201...7V047-4533.pdf
      2003 E46 M3 TiAg/Cinnamon 6MT
      2005 E46 330i ZHP Imola/Sand
      Instagram:@thegenius46m
        Corey, have you seen facelift E46 m3 with white labeled airbags that don't need replacement?
          Originally posted by thegenius46m View Post
          this is perfect. Thank you!
          Obioban is there a way to sticky this PDF?
