Does anyone know the proper valve adjustment specs for Schricks cams 280/272? I recall reading somewhere that they're different than the OEM camshaft valve clearance specs.
Schricks cams valve adjustment specs?
IIRC, all Schricks from 272 to 304 are supposed to be 0.25mm.
Sent from my SM-G950U using TapatalkYoutube DIYs and more
"Ventilspiel" .25mm for both intake and exhaust yes.Originally posted by digger View Post
I think Catcam recommended me OEM spec, which for intake is max .23 which isn't too far off, as well as exhaust min being .28 from memory also isn't too far off..
Regards
yes, 0.25 mm. You can right click and select translate to English (in chrome).Originally posted by Mr.wReckless View Post
Regards
