SMG Detent orientation and GT1 (gear adapations) for Win 10 question
    Put new GPS in place of the original GPS that was failing intermittently.
    For three days the GPS would fail and my tranny would go to default: Gears 2.5, and 6 and R only. I drove the car like that for a few days and the GPS would decide to work again and the SMG would work like it did in 2002. Just fine...until the GPS would go out five days later.
    At the time we replaced the GPS(two weeks ago) it was in one of its brief operational modes. SMG was fine, but the periods of time the GPS would not work were getting greater. Cog was almost always lighted even if the GPS was working fine. Once in a while the GOG would go away for 12 hours. Then come back.
    Now, I have a car with ZERO gears. N only.
    We went from a working SMG (sort of) and perfect running car to one that will not go or show any gear but Neutral.
    INPA gear adaptations would always quickly FAIL. I would disconnect the battery in between attempts in order to start with a freshly reset tranny.
    It seemed that the SMG pump, valves and solenoids PASSED. Plenty of pressure. I always had no issues with that. INPA shows 85 or 87 bar.
    I was highly urged by some members here to install a new roller detent and two detent springs. On advice we also replaced a temp sensor and a crank speed sensor.
    On this realoem diagram we replaced parts 5,6,7 and 9. Note part #7, the roller detent. I have a question about that. My helper just inserted it with out any orientation at all. Does that detent NEED to be inserted in a specific orientation??? ie roller portion parallel to the drive shaft or perpendicular?
    https://www.realoem.com/bmw/enUS/sho...56#23317530787
    On this next diagram we replaced parts 10 (crank speed sensor) and 13 (Temperature sensor coolant / oil). and part 2 (the Gear identification switch AKA GPS)
    I double checked the GPS shaft end. It is oriented perfectly with a little bit of fresh grease. That IS important.
    I even purchased another GPS just in case the first one was faulty. Both came from reliable suppliers. I believe they BOTH are working properly....but car no workee. No tranny gears!!! Just in case I took out the newly inst3alled used GPS and installed another LOW mileage GPS (75K miles) off an SMG tranny throwing NO codes at the tome of removal from the donor car.
    I checked all the PINS in the electrical connectors. Clean and FINE. No issues.
    I can only think of two things:
    1) The part#9 roller detent is not oriented correctly.
    2) My IPNA just isnt cutting it. I have heard GT1 software coming to the rescue.
    My DIS/GT1 from BC cables it supposed to work on Win 10. It does NOT!!
    I tried BC Cables INPA AND Mikes Tools INPA. They seem to be 100% identical. I get the same results from both of them. A HUGE FAIL on gear adaptions.
    We did tilt the tranny down 10 degrees to get access to everything. But we always had it bolted back in place PARALLEL with the ground....within 2 degrees or so.since the gar is on a tiny tiny bit of a slope. Only a couple degrees off level. The car is on giant 6 ton jack stands. Do I need to take a freaking LEVEL and SHIM my rear jack stands? I cant believe a few degrees off level would mess up gear adaptions.
    Where can I get a copy of GT1 that will work with Win 10??
    https://www.pss-autosoft.net/alt-order.php
      “On this realoem diagram we replaced parts 5,6,7 and 9. Note part #7, the roller detent. I have a question about that. My helper just inserted it with out any orientation at all. Does that detent NEED to be inserted in a specific orientation??? ie roller portion parallel to the drive shaft or perpendicular?
      https://www.realoem.com/bmw/enUS/sho...56#23317530787​”
      The roller rides on the tail end shift rod, so it rolls in the front/back direction
        So the roller needs to be PERPENDICULAR to the drive shaft? Just to be 100% clear. Right?
        Waiting to get some help this weekend and drop/tilt the tranny down to access that difficult friction fit blind plug covering the spring and that roller (locking) detent.
          AH! Perfect. I reached out to him to confirm a few things. This looks like the guy (Mario) I should have STARTED with regarding BMW software and compatibility with my Win 10. THANK YOU!
            So, IF the roller is way misaligned with the tranny inner workings, would that make the gear adaptions FAIL? By all accounts, the adaption should work fine. My SMG seems to pass all other tests. It FAILS the gear adaption so bad that I have ZERO gears. Neutral only.
              I said: "The roller rides on the tail end shift rod, so it rolls in the front/back direction."
              The roller rolls in fore/aft front/back direction, which mean it rolls (if you let it freely rolls) parallel to the tail shift rod or the driveshaft.
              How it works: the tail shift rod has a bump (dip and bump like speed bump on the neighborhood road) at the location of the neutral, so when the shift rod moves forward when engage even gears, or moves rearward when engage odd gears and Reverse, the roller pin rises up from the neutral deep, and this activates the detent mechanism on the shift rod, and also the GPS switch for the manual tranny.
                Pretty sure I understand that correctly. The roller and roller axle need to be in the up and down position in order to roll parallel with the drive shaft. Got it.
                The diagram on BMW realOEM shows the opposite,, but you can't rely on those diagrams for orientation.... that's why I thought I'd ask. .
                THANKS.
                  The actual SMG adaptation routine is the same in DIS, Inpa and ISTA-D. It does not play a role which program you use. Much more important is to verify that the cable has ignition detection. Many China cables do not have this, but it is needed for the adaptation.
                  SMG Society - parts and rebuild services for the SMG transmission
