Do you start rolling in 2nd or 1st gear?
    Driving alone and zero load, I think starting in 2nd is less work for me and the slave cylinder. Any body else?
    First. Its no 'work' for me and I don't think about component cycles..
      Maybe I'll do 2nd in my 7 speed e90, but not in E46. I, too, don't care about wear only driving 1k a year if that.
        I start in 1st, with 4.10's that means about 1 car length before 2nd gear, especially when warming up and shifting out at 3.5k max.
          This is a classic sapote question.
            Listen, spliffs don't get rolled until fifth gear holmie.
            Edit: Totally a joke.
              I usually start rolling after about 20 or 30 minutes
                If i’m already rolling (10kph) I jam it in 2nd.
                  What problem are you having/trying to solve? Are you replacing slave cylinders too frequently? You want a 5 speed? You want taller gears? Why care?
                  Youtube DIYs and more
                    It’s more work on your clutch. Downshift into first when rolling at some speed is easier if you double clutch.
                      Exactly what I do. Double clutch with a quick blip to sync up the first gear synchro.
                      Really satisfying when you get it perfect.
                        You can't double clutch on a tranny with synchros. I think you mean rev-match. Double clutching is an old term from old transmission days before synchros.
                        Getting into our getrag's 1st gear is a little easier at a very very slow roll (1 mph) vs dead stop in a lot of cases. If rolling like 2-3 mph,a little gas helps. Don't do it at any speed beyond that imo.
                          From a stop, I always start in 1st but then I'll go straight to 3rd for a smoother shift.
                            why would you want to ride the clutch more than necessary? if it is a rolling start, at 3-5mph then yes, but from a standstill just use 1st gear
                              You can absolutely double clutch a transmission with synchros. It is not necessary to do so, but it does save a slight bit wear on the synchros if done correctly.
                              While double clutching on a downshift, you would rev-match.
