RTD shifter issue
    RTD shifter issue
    Can’t seem to shift into reverse or 1/2 easily. Any tips? I reused the smg threads so there’s no downward bolts hitting the dssr. Haven’t bleed the clutch yet so I’ll do that today.
    did you loosen the adjuster screw and center the shifter?
      Yea I did, which made the 1-6 shifts better but reverse is now popping out if I don't get it in right. Also sometimes 2nd grinds. Idk if my tranny is bad or install error
        what mounts (Trans & motor)? For second gear issue. I have poly and it works perfect. I dont see how this could of been messed up. maybe loosen the 3 screws holding it and make sure it stays in reverse. Ive had no issue and the shifting was ev evn better when I adjusted using the screw
          Stock old motor mounts and Ecs tuning 70a tranny mounts. I am going to order some 80A engine mounts to give it a try.
          Yea I can’t see it being messed up either, pretty straight forward install. Unless I messed something up with the bellhousing or tranny install when I deleted smg. I’ll try adjusting the 3 screws and position.
