Can we talk about ceramic coatings?
    I throw a newer set of products I've been using since the thread was resurrected. I've been very impressed and cost wise they are competitive. If you get bored and want to try something new, this is for you.
    Coatings:
    Shop ceramic coatings, spray sealants and detailing sprays for paint, wheels, glass and trim. Find the right protection for your car at Armour Detail Supply.
    Rinseless
    Wash without a final rinse using HERO Rinseless Wash. Its slick formula lifts dirt and grime without adding wax or protection to your existing finish.
    Detailer
    Add gloss and slickness with AMPLIFY, a SiO2-infused detail spray and drying aid. Use after washing to maintain your car’s coating, sealant or wax.
    Interior
    Clean and refresh your cabin with PILOT Interior Detailer. Lifts everyday grime from leather, plastics, screens and more while leaving a matte factory finish.
      Originally posted by cidini
      For a practical, low‑maintenance approach: coat your wheels with a wheel‑specific ceramic product so brake dust and grime rinse off easily after track days. Protect clear‑coated carbon fiber with a carbon‑fiber‑safe ceramic coating to guard against UV and slow yellowing, washing gently with pH‑neutral shampoo. For the body paint, a good ceramic coating provides water and UV resistance, keeps cleaning simple, and accepts that minor rock chips or wear from normal use will happen; if you want extra protection in high‑impact areas, a small strip of paint protection film can help, but it’s optional.
      Funny you mention carbon fiber, I had an issue with ceramic coat ruining the clear and resin on a carbon sunroof plug. The manufacturer replaced it and said just use regular car wax on it. I don’t feel like experimenting on that part of the car again lol BUT does anyone have a known product that is safe for carbon fiber?
        Hey everyone, I know very little about the different paint and finish protection options out there, but I know there are experts on this forum. Thought maybe we can get a dialogue going on some of the better products. I'm also curious about ceramic coating cost and whether the investment is worthwhile for someone who wants practical protection without going overboard. I am not a detailing guy, never have been, nor are my cars immaculate. I don't need the obsessed garage approach of maximum OCD solutions. More like, the working man's solution to reasonably protect your car, which still gets dirty, rained on, tracked, and otherwise fucked with.
        First question: best way to protect wheel finish and make it easy to clean after track use?
        Second question: best way to protect clear coated carbon fiber, and minimize yellowing?
        Third question: best way to protect paint, if different than the above?
        Thanks!
        I think you're approaching it the right way. You don't need an expensive, complicated detailing routine to get decent protection. For wheels, I'd look into a quality ceramic coating or dedicated wheel sealant. It makes brake dust and track grime much easier to wash off. For clear-coated carbon fiber, a good UV-resistant ceramic coating can help protect the finish and reduce UV exposure, which contributes to yellowing over time. For the paint, I'd go with a quality ceramic coating if you want longer-lasting protection and easier maintenance. The key is finding a practical solution that doesn't turn washing your car into a full-time job!
          I've been applying collinite insulator wax annually after a decon/polish, with spray wax applied after every wash and the protection has held up.
          collinite is as easy as it can be to use and cheap. ceramic coatings may work better, but for me collinite is good enough.
          I did apply P21S carnuba over the top of collinite last year and they reacted with each other creating a rainbow effect, so don't do that.
            Carbon fiber/epoxy parts will always be an issue. Automotive paints are typically polyurethane based which does not chemically bond to epoxy. The bond can be improved by scuffing the surface up more coarsely than usual. I am not a paint expert so not sure about the exact specs but this is information from people that have been in the business for decades.
            Clear coat will fail. PPF, wax and other coatings will help extend the life but it will fail.
            One epoxy compatible finish is duratec sunshield which is typically used as a spray in mold coating. I'm sure it can be sprayed in post cure but I believe part of the advantage is to bond to the epoxy as it cures.
            Long story short, I wouldn't beat your head in trying to make the clear coat over epoxy/carbon fiber last forever. It won't.
            There are some parts that are carbon fiber / polyester resin - those typically will be lower cost and mass produced like Seibon and VRS - those will bond well to clear coats.
              Yeah, you're going to get a million different responses here.
              The guys who say it isn't worth it, I guess don't care what their car looks like. Cause, it is very noticeable when a car is or isn't coated.
              PPF and Ceramic are very different things, and serve different purposes. I don't know anybody who does PPF and then doesn't coat it.
              On my show winning cars, I use Armor Detail Supply as well. I've tried everything, and for the price and ease of application, this stuff is hard to beat.
              Protect your finish with Armour PRO Quartz Coating. LayerSync Bonding delivers gloss, chemical resistance and water repellency in a single-layer application.
              2004 Dinan S3-R M3
              2023 X3M Competition
