I need some help with my CSL box underside Crancase Breather Hose connection
    Managed to break the receiver for this piece Click image for larger version
Name:	Screen Shot 2023-03-31 at 1.09.20 PM.png
ID:	212138 off my CSL box, it is not from a current manufacturer, from a past M3forum group buy from Repo? maybe, can't recall. Anyways, point is I need to repair it and I don't want to buy a stock airbox and hack it up to get the female receiver piece. Any suggestions?
    Can you replace the line from the canister piece in your pic with appropriately sized fuel hose, and use a generic fitting + hose clamp on the airbox?
      That would probably be the best solution actually. Not sure why I am trying to overcomplicate this actually.
        Because that's the German/BMW/M3forum way !
          my next trick is going to be sending in a set of blown out V3's for rebuild and end up spending more than I'll be able to sell them for
            Do you have a picture of the airbox and the fitting? The "Repoman" airbox was the early Karbonius airbox. The one before that was the one made by Randy Major from Carbon Concepts. And then there was the VAC airbox which had a connector like the one you are describing.
              photo of the box, I don't have the underside at the moment as it's currently mounted
