As said above change the muffler first, I've had that exhaust on my car. Keeping that muffler and messing around further back in section 2 or changing headers seems like a waste of time.
Better options out there that won't hurt your budget, or just go back to stock.
Best E46 M3 Full Exhaust setup for the money?
Actually maybe the less vocal majority. If you just want to change the sound of the exhaust, yours is a pretty straightforward solution. Personally, I don't care about the sound and want to get the restriction out of the headers while still having high quality parts with good fitment. So in my case it's the opposite: swap the headers and S1 and leave the muffler and S2 alone.Originally posted by tvan View PostI’m probably in the minority here but have really found that for a street car it’s best to just change the muffler and leave the rest alone.
I have a SGT Scorza and the only one I’ve heard that is consider swapping for is Dinan. I’m sure Supersprint is great, though I’ve never heard that one on a car that didn’t also also have aftermarket headers.
Nice thing about Euro headers and cats is swapping to the OE Euro tune matches right up and it's free.Originally posted by MarcoPolo View Post
also makes sense. if you're not going to do much to the car other than change the way it sounds, that sounds like a good idea. i ended up getting tuned as well so for me, a tune on a mostly stock car is a waste of money. going catless on the headers is typically the first step in freeing up airflow.Last edited by ethan; 05-10-2020, 10:06 AM.
also makes sense. if you're not going to do much to the car other than change the way it sounds, that sounds like a good idea. i ended up getting tuned as well so for me, a tune on a mostly stock car is a waste of money. going catless on the headers is typically the first step in freeing up airflow.Originally posted by tvan View PostI’m probably in the minority here but have really found that for a street car it’s best to just change the muffler and leave the rest alone.
I went through this over the last 6 months so i will add my $0.02. I first did euro headers/section 1 with OEM section 2 and SCZA Muffler. while it sounded 'okay' from inside i could tell that it had a bit too much rasp (to some, this is great, but not for me), which made sense because if you do the math, i went from 2 cats/ 2 resonators to 2 cats / 1 resonator so i guess i expected more rasp.
Video: https://youtu.be/R4c_3CX1T0M
Once i accepted the fact i didn't like the rasp, i moved over to a SuperSprint Section 2. i read that it was an upgraded resonator, which makes up for only having one...it changed the tone to this:
Video: https://www.youtube.com/watch?v=2D7A1Ewk3AU
i like the subtle rasp with a good tone. under normal driving conditions it doesn't sound loud at all. may not be what you want but at my age (40) i'm not looking to be driving down the street making too much noise.
- Likes 3
Balancing volume/cost/performance my ideal setup would be Euro headers > Euro catted Sec 1 > OE sec 2 > Dinan muffler. Great sound, perfect fit, no drone, and can be done under $2k all in.
Backfires and that noise level would drive me nuts on the street, but de gustibus non est disputandum. Just depends on what you're looking for. I like the stock Euro setup:Originally posted by Stack View PostI have SGT full exhaust.
SGT Headers
SGT Section 1 ( no cats)
SGT Section 2 ( Non resn)
SGT SCZA section 3
I wouldn’t call it cheap. I was super picky in choosing the exhaust system for my car, I felt this was the best sounding option IMO.
QFT. And IMO, the best noise from an S54 comes from the front end of the car, not the back. Just have to put the right airbox on it.Originally posted by Obioban View PostBest bang for buck is euro headers and section 1, stock section 2 and muffler.
That's a great comparison video. The cameras are always a little weird when picking up the rasp but nonetheless that sounds great!Originally posted by Stack View PostI have SGT full exhaust.
SGT Headers
SGT SCZA section 3
Euro. Headers/Sec. 1 for the MONEY and KNOWING it will fit. Sec. 2 and muffler can then determine sound as well as a bit of power likely.
SGT Headers
SGT SCZA section 3
Here's a guy that has a decent sound without resonators. He has the Supremo from Megan Racing and Status Gruppe headers. I personally wouldn't buy their muffler but his sounds pretty awesome above 4k.
And being on a budget is fine as long as you aren't cheaping out on maintenance. Some people on here have spent $5000 on their exhaust. I spent $250 on my headers, which are Megan Racing, and $650 a used GruppeM muffler. My goal was to keep the cost low and it turned out awesome.Last edited by Arith2; 05-06-2020, 07:32 PM.
Only problem with this is that the pipes rub slightly. I get some rattling on cold starts, I've decided to just live with it until I upgrade the whole exhaust system. I'm sure welding on a bracket between the two pipes would fix this, but I just can't be bothered.Originally posted by Obioban View PostIf you're just going after sound, I'd do the 2x resonated factory section 1 pipe solution. Cheapest once labor is factored in, and you get OE build quality instead of whatever local shop welds in a not amazing quality resonator for you. Should be easy enough to pick up a used US section 1 from someone on here that has gone to an aftermarket section 1.
The AR25 definitely tames the Megan and makes it sound pretty decent for the cost. You might end up liking it. 😀
