Best E46 M3 Full Exhaust setup for the money?
If you're just going after sound, I'd do the 2x resonated factory section 1 pipe solution. Cheapest once labor is factored in, and you get OE build quality instead of whatever local shop welds in a not amazing quality resonator for you. Should be easy enough to pick up a used US section 1 from someone on here that has gone to an aftermarket section 1.
Originally posted by Ob917 View PostI added a ar25 to section one. In my opinion it sounds way better. Cost me $100 to have a shop do it, I brought them the section off the car. I couldn’t justify spending $400+ and not getting anything except a change in tone.
Should I go two AR-20s side by side in section one? or stock section one resonator with one ar-20 on the other side? I imagine they would sound pretty similar.
Looks like I wont worry about changing section two for now. Thanks!
Same as guys said weld extra resonator to section 1 or buy some used one with double resonators. There is no reason to change section 2 if you don't have complete aftermarket exhaust. Stock is really good.
Originally posted by enjoy_m3 View PostYour best bet is just to ad a second resonator to section 1. The x-pipe will drone around 2500 to 3k rpm even more and you'll loose midrange torque.
For a super budget solution, buy a used stock section 1 and chop it in half to separate the unresonated and resonated pipes. Do the same to the stock section 1 on your car then install both resonated pipes.
Best option in what, sound (strongly subjective) or gain in power (minimal without supporting mods)?
For sound, I find my all stock with modified section 3 plenty loud; yet retains E46 M3's exhaust note very nicely.. (Subjective)
For power; I believe others will chime in with much more in depth knowledge..
I had the subframe reinforced... just looking for a few options for exhaust mods under $1000. thanks.
Ironically, the cheap stuff like Megan & SGT is a worse use of money than buying the best, expensive stuff like Supersprint v1.
Owning an M3 and being on a budget isn't a great combo, so i would recommend you keep the car stock and use all "car funds" to address maintenance. And don't say your maint is all done cause you changed the oil and the dealer "looked" at your subframe (RACP). You could spend tens of thousands refreshing the car, even at discounted online (OEM/OES) parts prices.
- Likes 8
Best bang for buck is euro headers and section 1, stock section 2 and muffler.
- Likes 6
Right now I'm only running a Megan Racing muffler (I know probably not the best but I'm on a budget) and the rest stock. Overall I really like it for the money, but I notice some drone and also a bit more rasp than I probably want.
I bought some catless headers and plan on installing these soon, which I'm worried will only accentuate the drone and rasp. Should I add an Ar-20 in the section one. Should I buy a status Gruppe resonated X pipe? What would be the best bang for buck to add to the section 1 & 2. What is the benefit of the X pipe and what generally sounds best or what setups do you guys run/ like?Tags: None
